MoboCop Drunken Master
adrian_k Initiate
Posted: Tue Nov 09, 2004 1:16 am Post subject: a suggestion |
I don't have a great deal of exp. w/ building pc's so when it says something like 'the power cable goes over the processor' or the 'video card blocks the ram' I find it hard to visualise.
Si it'd be nice to have a photo of the problem just to see how bad it is.
cheers
Adrian |
Posted: Tue Nov 09, 2004 8:38 am Post subject: |
board shot
http://www.motherboards.org/imageview.html?i=/images/mobot/motherboards/7421.jpg
If you look at above image. Check the lime green slot in middle of board (pci express x16 or video slot). Just below this slot and to the right you can see two sets of memory slots (yellow and blue). Now when a video card is installed it is typically longer than the slot by at least a few inches and in a layout like this will prevent you from opening the white locking mechanisms on the memory slots.
As for the power cable you can see its location at the bottom right corner of the motherboard directly in line with the cpu socket. A better ergonomic placement would be somewhere in the top left side of the board. _________________ Not everything that can be counted counts, and not everything that counts can be counted - Albert Einstien |
evasive Mobo-fu Master
Joined: 06 May 2001 Posts: 33004 Location: Netherlands, Breda
Posted: Tue Nov 09, 2004 9:30 am Post subject: |
| Quote: | | As for the power cable you can see its location at the bottom right corner of the motherboard directly in line with the cpu socket. A better ergonomic placement would be somewhere in the top left side of the board. |
Provided you have a power supply that can reach with its cable. Value power supplies have very short cabling sometimes, I can see what segment this board is pointed at already... _________________ We hate rut, but we fear change.
Just became a fan of Intwine
profofpcs Black Belt 5th Degree
Joined: 08 Jul 2002 Posts: 9884 Location: gold country
Posted: Tue Nov 09, 2004 9:43 am Post subject: |
ok, are they trying to phase out IDE altogether? on all the newer boards ive seen, there's only one IDE port, and the cdroms need them. so, are they going the way of the isa slots? will we soon HAVE to buy SATA drives? _________________
anger is just danger without the "d" |
EmilyB Guest
Posted: Tue Nov 09, 2004 11:11 am Post subject: |
| cacrusn wrote: | | ok, are they trying to phase out IDE altogether? on all the newer boards ive seen, there's only one IDE port, and the cdroms need them. so, are they going the way of the isa slots? will we soon HAVE to buy SATA drives? |
I have seen some SATA DVD drives, so I imagine IDE will be phased out eventually  |
dallascisco Black Belt 3rd Degree
Posted: Tue Nov 09, 2004 11:52 am Post subject: |
| EmilyB wrote: | | cacrusn wrote: | | ok, are they trying to phase out IDE altogether? on all the newer boards ive seen, there's only one IDE port, and the cdroms need them. so, are they going the way of the isa slots? will we soon HAVE to buy SATA drives? |
Eventually, I've seen some rom drives using sata but that will take time. |
snap355 Black Belt 5th Degree
Ryn Black Belt 4th Degree
Joined: 11 Jan 2004 Posts: 4387 Location: Manila, Philippines
Posted: Wed Nov 10, 2004 3:18 am Post subject: |
| snap355 wrote: | | Will SCSI ever be mainstream for desktops or it's reserved for servers because of costs and such? |
i dont think SCSI will be mainstream for desktops since it is designed to be used 24/7 on a server. _________________
Join the Motherboards.org Folding Team 33258 |
