MoboCop Drunken Master
Peanya Black Belt 5th Degree
Posted: Wed Nov 10, 2004 5:13 pm Post subject: |
| Hmm maybe all the epowers are made by Tagan. Same case and cables (almost) as my OCZ. The split rails concern me though. |
dallascisco Black Belt 3rd Degree
Posted: Wed Nov 10, 2004 5:23 pm Post subject: |
| Peanya wrote: | | Hmm maybe all the epowers are made by Tagan. Same case and cables (almost) as my OCZ. The split rails concern me though. |
How do those split rails work? |
poiuy223 Green Belt
Posted: Wed Nov 10, 2004 5:37 pm Post subject: |
epower makes all the power supplies. tagan is not the maker, but a model name.
the need for split rails is due to intel's new 12v v2.0 standard. it helps feed power more stably. there are two independent 12v rails. one is specifically only for the 12v 4pin, which is for the cpu. the other rails is for the rest of the components, like video card and hds and such. when you have a power hungry cpu like the prescott and pair it up with a power hungry video card, let's say the 6800 ultra, a single rail can't hold as well. the split will be better |
Posted: Wed Nov 10, 2004 7:29 pm Post subject: |
| Quote: | | epower makes all the power supplies. tagan is not the maker, but a model name. |
I've heard differently. Also the parts in and out are labeled as Tagan. And Tagan is also a company www.tagan.com I could be wrong! |
poiuy223 Green Belt
Posted: Wed Nov 10, 2004 7:40 pm Post subject: |
hmmm. perhaps im wrong. im gonna double check my sources.
hmmm. i dont know if there is a typo or an error somewhere, but i wrote the "mini" review, not doc. |
Posted: Wed Nov 10, 2004 11:12 pm Post subject: |
| poiuy223 wrote: | hmmm. perhaps im wrong. im gonna double check my sources.
my bad. or actually doc's bad as he did not tell me who wrote it. I will fix it now. _________________ Not everything that can be counted counts, and not everything that counts can be counted - Albert Einstien |
poiuy223 Green Belt
Posted: Thu Nov 11, 2004 1:44 am Post subject: |
| thanks pat. |
